Boost Roll Call... if you've got it, come on in!
Old Apr 28, 2005 | 02:24 PM
  #61
slimdawson's Avatar
Re: Boost Roll Call... if you've got it, come on in!
I am assuming that car isn't the same as the one in the sig since it doesn't have stock suspension.
Old Apr 28, 2005 | 02:32 PM
  #62
Ponyhntr's Avatar
It is stock style, though.
Old Apr 28, 2005 | 03:44 PM
  #63
guardrail's Avatar
Originally Posted by engineermike
What's wrong with the Eagle crank?
I've had a lot of little issues with the hub, I wouldn't necessarily pin it on the crank, but I've heard some bad stories about eagles.
Old Apr 28, 2005 | 08:58 PM
  #64
TravisA's Avatar
Originally Posted by tubby
383
heads-stock
intake-stock
TB - stock
suspension- stock
trans -th400
procharger F1
9.515 @ 140.71
Stock heads,intake and TB?? The heads and intake are ported stock ones,Right?
Old Apr 28, 2005 | 09:29 PM
  #65
slimdawson's Avatar
True, but stock does not equal stock style. Nor does stock heads=stock ported heads.
The car is fast however.
Old Apr 28, 2005 | 09:56 PM
  #66
Ponyhntr's Avatar
True, but in the racing community, aftermarket replacement parts=stock. Not only does this apply to F-bodies, but in all race organizations.
Ladder bars, 4-links, ect. are obviously not stock.
Old Apr 29, 2005 | 08:01 AM
  #67
LittleRedZ's Avatar
junk that is whats wrong with it
after 400 miles my crank snout snapped(eagle says due too much belt tension on the 12 rib belt ) and that was just putting around breaking the motor in. Scat crank has been in the car for around 2k miles now, i've dynoed the car about 4-5 times, and made 8 passes+street racing some, and no problems knock on wood.
Old Apr 29, 2005 | 08:23 AM
  #68
tubby's Avatar
yes, stock style. orig. panhard and LCA's aftermarket TQ arm and k-member. believe it or not heads are stock. reason for posting this was that i was so impressed by what you can get out of a stock top end. forced induction just doesn't play by the same rules. hyd. cam gave out at 6450 rpm or it would have had a little more in the 1/4.
update: last sat it went a 9.523 @ 142.81
Old Apr 29, 2005 | 08:50 AM
  #69
Ponyhntr's Avatar
Tubby-
How much boost you getting out of that F1? What size pulleys?
Old Apr 29, 2005 | 09:04 AM
  #70
tubby's Avatar
knowing that the head gaskets could only take so much i ran a set of underdrive pulleys which gave me right at 14# boost. sure enough we blew a gasket but it was worth the R&D IMO because this was sort of a back up motor anyway. we just wanted to try a few things with it. i'm so impressed with it though now i'm thinking of putting a solid cam in it and o-ring / stud the heads and see what it will do.
Old Apr 29, 2005 | 09:23 AM
  #71
Ponyhntr's Avatar
What gaskets were you running? Instead of o-ringing the heads, you might try a Cometic gasket-we have had lots of luck with them.
Your car is FLYING for what you have in it!
Old Apr 29, 2005 | 09:26 AM
  #72
Birdie2000's Avatar
Are the stock heads ported? Intake ported?
Old Apr 29, 2005 | 09:44 AM
  #73
tubby's Avatar
nothing is ported. the motor wasn't assembled with this kind of boost in mind so the gaskets weren't anything special. we run 17# boost on the other motor with o-ringed copper. never had any problems so i'll probably just go with that.
Old Apr 29, 2005 | 09:58 AM
  #74
TravisA's Avatar
Wow that is impressive!
Old Aug 30, 2005 | 07:50 PM
  #75
aggiez28's Avatar
