Boost Roll Call... if you've got it, come on in!
Old Apr 14, 2005 | 10:19 PM
  #31
blown69nova's Avatar
Re: Boost Roll Call... if you've got it, come on in!
Hi guys,all forged 9:1 383 sbc, TFS 195 heads, miniram intake, 58mm tb, xe224/236 116lsa high lift, Electromotive tec2, 72lb injectors, A1000,D1SC non intercooled, 7.65" and 4" pulleys. I'm using a full manual TH400, vigilante 3200 stall and a 9" rear.
I have another couple weeks of work before it's done, so I have no numbers. Any guesses?
Oh yeah I forgot to mention it's in a 69 nova!
Steve
Old Apr 14, 2005 | 10:39 PM
  #32
275HP's Avatar
stock displacement lt1
ported lt4 heads
ported lt4 intake
comp cams blower cam
p1sc
hooker lts
motor is at the machine shop and the heads and intake are being ported so when it comes together I will post dyno numbers and track times. I just hope that they are pretty good, or I will be really upset.
Old Apr 15, 2005 | 09:58 AM
  #33
speedmiser's Avatar
See sig - been running approx 14psi on pump gas w/ TH400 and 4k stall - 4 corner Qa1's and Strange 12 bolt. Fuel system is A1000 and -10 line.
Current rebuild is incorporating a 4" thick FMIC and DP fogger setup, to help out the litttle S-trim
Old Apr 15, 2005 | 10:29 AM
  #34
flusz28's Avatar
i'm blown still putting the motor together and need to have it dyno tuned.
Old Apr 15, 2005 | 01:31 PM
  #35
Ponyhntr's Avatar
Stock short block, CC306, ported stock heads (bigger valves) and intake, Hooker LT's, Lane's true duals with X and bullets, 12 bolt, M6 with a slipping Spec Stage III, and ATI D1SC running about 6 psi boost.
Old Apr 15, 2005 | 02:21 PM
  #36
Acct 23749's Avatar
1997 camaro SS 30th anniversary ed'
6spd hard top
P1-SC with 7psi through twin hi-flows feeding a 58mm TB, Ported intake/heads, 355 LT1 4 bolt conversion, billet caps eagle forged crank and H-beam rods, SRP forged dished pistons, custom grind cam, CC875R lifters, CC977 springs, Hooker LTs, TOLT
no dynos yet, not track times yet, still got the stock 10 bolt
very very fast though
www.cardomain.com/id/camarossguy2 for details
Old Apr 15, 2005 | 04:05 PM
  #37
94SLUG's Avatar
First page of webpage
Old Apr 15, 2005 | 07:04 PM
  #38
engineermike's Avatar
Originally Posted by camarossguy2
P1-SC with 7psi through twin hi-flows feeding a . . .
Is ATI/Procharger still using straight vanes on the compressor wheel?!?!
Old Apr 15, 2005 | 08:37 PM
  #39
lethal93ta's Avatar
the P600B and P1sc has the straight vains on them, anyother model above that has curved ones.
Old Apr 15, 2005 | 09:42 PM
  #40
DarkblueTA's Avatar
That's only on the LT1. LS1 the P1SC is curved.
Old Apr 16, 2005 | 10:37 AM
  #41
SilverStreek's Avatar
Sig says most of it....I didn't get to run it after the rebuild (obviously), but before the rebuild with compression down on 5 cylinders it ran 12.9@115mph on greasy streets. However, I just drug a S&W rollcaged rolling chassis home from Georgia.....won't have to cut me out again......
-Michael
Old Apr 16, 2005 | 10:51 AM
  #42
Chrisbequick's Avatar
Homebuilt turbo kit w/:
HKS T51R SPL turbo
Blitz intercooler
Turbonetics Racegate
355 LT1 w/:
Forged Sealed Power 9.5:1 pistons
Stock crank and rods
home ported heads
Comp 220/230 cam
569rwhp @ 9psi
-Chris
Old Apr 16, 2005 | 11:27 AM
  #43
slimdawson's Avatar
Chrisbequick, that looks like a nice setup. About time to change those rods and crank, right?
Any pics of the car?
Old Apr 17, 2005 | 07:40 AM
  #44
1st and goal's Avatar
383 D-1 19#, 3 core FMIC, CNC heads, JE Pistons, Callies crank, CC305 cam, FLP longtubes w/ 4" Mufflex, FAST, custom LS-1 coil pack ignition
654 RWHP
580 RWTQ
10.02 @ 135.71 - best ET
136.68 - best mph
Marc
Old Apr 17, 2005 | 09:35 AM
  #45
I've got pics, but not online. I'm working on my new website. It will be up in a few days.
I just got done building the motor. I'm not about to build it again anytime soon.
-Chris
