Boost Roll Call... if you've got it, come on in!
Re: Boost Roll Call... if you've got it, come on in!
Originally Posted by slimdawson
I am assuming that car isn't the same as the one in the sig since it doesn't have stock suspension.
Originally Posted by engineermike
What's wrong with the Eagle crank?
Originally Posted by tubby
383
heads-stock
intake-stock
TB - stock
suspension- stock
trans -th400
procharger F1
9.515 @ 140.71
heads-stock
intake-stock
TB - stock
suspension- stock
trans -th400
procharger F1
9.515 @ 140.71
Originally Posted by Ponyhntr
It is stock style, though.
The car is fast however.
True, but stock does not equal stock style. Nor does stock heads=stock ported heads.
Ladder bars, 4-links, ect. are obviously not stock.
after 400 miles my crank snout snapped(eagle says due too much belt tension on the 12 rib belt
) and that was just putting around breaking the motor in. Scat crank has been in the car for around 2k miles now, i've dynoed the car about 4-5 times, and made 8 passes+street racing some, and no problems knock on wood.
yes, stock style. orig. panhard and LCA's aftermarket TQ arm and k-member. believe it or not heads are stock. reason for posting this was that i was so impressed by what you can get out of a stock top end. forced induction just doesn't play by the same rules. hyd. cam gave out at 6450 rpm or it would have had a little more in the 1/4.
update: last sat it went a 9.523 @ 142.81
How much boost you getting out of that F1? What size pulleys?
knowing that the head gaskets could only take so much i ran a set of underdrive pulleys which gave me right at 14# boost. sure enough we blew a gasket but it was worth the R&D IMO because this was sort of a back up motor anyway. we just wanted to try a few things with it. i'm so impressed with it though now i'm thinking of putting a solid cam in it and o-ring / stud the heads and see what it will do.
Your car is FLYING for what you have in it!
nothing is ported. the motor wasn't assembled with this kind of boost in mind so the gaskets weren't anything special. we run 17# boost on the other motor with o-ringed copper. never had any problems so i'll probably just go with that.
