best place to mount boost-a-pump
Re: best place to mount boost-a-pump
You want to mount it as close to the fuel pump as possible for minimal voltage loss coming out of the BAP. I have mine mounted under the driver's side rear seat cushion and it's spliced into the pump wiring very near the bulkhead connector. I also have a digital voltage gauge that reads the BAP output. This way, I can adjust it to the same exact reading every time. This is because the BAP's output is dependent on voltage input. The input (system voltage) is not always exactly the same, given conditions, electrical accessories that are running, etc.
Victor Lamb
Aug 26, 2017 02:52 PM
alex5366
Jun 7, 2015 08:50 AM
