Removing cats
Old Aug 9, 2010 | 01:02 PM
ascastil's Avatar
Removing cats
I have Pacesetter long tubes with two cats welded into the y pipe, o2 sensors before and after the cats. I want to remove the cats and was wondering if that will throw any codes.
Old Aug 9, 2010 | 03:14 PM
Yes - OBD-II uses the after-cat sensor readings to determine if the cats are there and working. If they aren't, is will set codes/SES light for "low cat efficiency". You can have the codes "tuned out" of the PCM, or you can buy a pair os O2 simulators ("sims") that plug in to the harness in place of the real sensors. Sims used to be easy to find, but a few years ago Casper - the main supplier - was fined $70,000 and forced to stop making them, because their use is a violation of Federal law. You can find them on ebay, but like anything on ebay, the quality is going to be a crap shoot.
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
