Who has done a 10-bolt buildup?
Old Apr 22, 2010 | 05:59 PM
pgm's Avatar
pgm
OK, this question is for those of you who have done buildups on your stock 10-bolt rears--by that I mean you have a solid spacer, support cover, tube brace and welded the tubes and so forth.
So how has this setup worked out for you guys? Which gear ratio did you go with? Did you upgrade the axles and/or carrier? DRs or slicks? Any 60' times?
I'm trying to decide whether to build the stock rear or just bite the bullet and get a 9" or S60. I would be doing 4.10s with an LS1 Torsen plus everything mentioned above. I don't foresee that this car will ever have more than around 430rwhp.
Old Apr 23, 2010 | 07:17 AM
AL SS590 M6's Avatar
Moderator
I built one for my A4 car and ran 1.5 60s and low 11s with a 3.42 gear with no problems at all.
But with an M6 I wouldn't waste my money on a stock rear. Spend it on a 12 bolt, 9'', or S60.
Old Apr 23, 2010 | 11:51 AM
Read these articles.... $1,690 invested and its only good for 450HP on an automatic, and not recommended for an M6.
http://www.highperformancepontiac.co...ild/index.html
Old Apr 23, 2010 | 01:53 PM
97SS0594's Avatar
3.42 gear, TA girdle all arp hardware, welded tubes behind a 700R4 and a built 355 on a 300 shot hangin the tires dead hooking on 10.5x26 ET street... no issues, oh cutting 1.50 footers also... rear is now under my 600WHP f1 procharged car.
TitoPR221
Jan 29, 2015 08:00 PM
movingviolation
Feb 18, 2003 02:06 PM
RedScreamin
Feb 12, 2003 12:53 PM
Distortion28
Classic Engine Tech
15
Oct 4, 2002 11:40 AM
awalbert88
3rd Gen / L98 Engine Tech
9
Aug 13, 2002 11:26 PM
