10-bolt vs. 12-bolt
don't know how much heavier a 12 bolt is, but yes it is p ossible to build a 10 bolt to last behind a mild motor. Ellis I believe had his 10 bolt in the 11's, but he pretty much rebuilt it every season. He also had an Eaton posi unit ($400 or so item). If you have the money, go with a 12 bolt.
look up at the top of the message board where it says User CP (control Panel). Click on that, then click on "Edit Profile". Your sig is i there
12 Bolts are quite a bit heavier. I tried to weigh them when I put mine in, but it's hard to do on a bathroom scale.
Anyway, if you have a 6speed car, you're just asking for it. My high 12 second car blew up 2 rings in around a year. Only one of those was on drag radials. The way i see it is, why not do it now? You'll have to do it eventually, and then you'll also have to foot the cost of 1500 dollars worth of gear changes. Think what i could have done with that extra 1500 dollars!
I tried comparing my stock 10-bolt to a Strange 12-bolt and there was less than 10# difference. But that was putting one end at a time on a bathroom scale. Point is, it isn't 200# heavier. And the Moser is probably slightly heavier than the Strange because the tubes are a little larger, and the brackets may be heavier (Strange uses "factory" brackets").
But considering that I did the entire install myself, laying on my back in a cold garage, it wasn't all that much heavier.
of course if you have the money, then get the 12bolt. you CAN build a 10bolt to be just as strong however. get some good axles, a good posi, and a strong set of teeth, and youll be good to go.
A4s will be much easier on whichever you go with BTW. a M6 with gears and traction will crucify a near stock 10bolt.
jon
jon
Originally posted by CANTONRACER
Injuneer - don't you have any friends??
.I guess that's my point... if a senile old fart senior citizen like me can do it, it can't weigh too much.
Card carrying member - NHRA and AARP......
it's true!
Originally posted by Injuneer
Yeh... but most of them are so old that they can't get too much time out of the rest home......
it's true!
it's true!
I hope when I get old enough to carry an AARP card I can still lay on the garage and do this stuff
Well mine is definitally auto and since I'm not trying to make some crazy 550hp to the wheels car I think a beefed up 10-bolt would be better. I figure 400-450 flywheel by the time I'm done. Probably like mid 1.8 60' times and hopefully low 12's. Nothing out of control.
RUENUF
Mar 13, 2016 03:37 PM
NewsBot
Jul 3, 2015 02:10 PM
