whats the fastest anyone has gone on a posi ?
Old Aug 28, 2003 | 08:55 PM
sideways_Into_3rd's Avatar
how fast can u go on a posi before it becomes so unreliable that u have to put in a locker or spool ?
im running measly high 11s and my posi is alreayd shot (12 bolt strange posi)
its a toss up between rebuilding the posi or putting a spool in there
Old Aug 29, 2003 | 09:11 AM
red's Avatar
red
I am currently running 11.20's on my Eaton in a Moser 12 bolt with no problems. The spray went back on the car this week and I will be running well in to the 10's and hopefully 9's. We'll see how well it stands up after those passes.
The real question is do you need a posi? Does the car see enough street time to make the posi rebuild worth it? If not the spool is the cheaper fix.
Old Aug 29, 2003 | 12:35 PM
EDS Z28's Avatar
You might have to use higher pressure springs in the posi unit. I know the Eaton uses 400 lbs stock. You can get 800 pound units, but it will create some chatter with street use.
Old Aug 29, 2003 | 12:44 PM
red's Avatar
red
I have the Eaton 800 # unit and there is no chatter in mine.
Old Aug 29, 2003 | 02:07 PM
I know George Baxter ran his 3,900# 30th SS convertible to the mid-9's on a Strange 12-bolt, with the Strange "super strength" posi. Then he switched to a Moser 9-inch with a spool. I also know he burned up the clutches of his "standard" Strange posi at about the 750HP level.
Old Aug 30, 2003 | 02:50 AM
atljar's Avatar
My rear end burned the standard posi in the strange. Upgraded to the Eaton HD unit and havent had any issues. (thing is $$$$$ tho!)
Old Aug 30, 2003 | 10:50 AM
OneFlyn95z28's Avatar
I killed my posi the first season. Kevlar clutches let go.
I am now running my eaton with the old school steel clutch pack and shimmed 800Lbs springs. it drives real nice and launches real straight
I have heard of many people fragging both the standard Strage posi and HD strange.
Boss002
Jul 24, 2015 10:47 AM
vwb11356
Jul 22, 2015 06:51 PM
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
