What flex plate???
Old 02-05-2007, 09:40 PM
snakeatinZ's Avatar
What flex plate???
What is a good Flexplate for me to go with? How many teeth does it need??? set up in sig.
Steve
snakeatinZ is offline
Old 02-05-2007, 09:53 PM
mdacton's Avatar
jegs has a descent one 555-60153
if you just want a stock one let me know....other than that you nd a 153 tooth for 1pc. seal 86-up
mdacton is offline
Old 02-06-2007, 12:02 PM
12SCNDZ's Avatar
I agree...Jegs has an SFI approved plate for less than a stock one costs.
Frank
CPT
12SCNDZ is offline
Old 02-06-2007, 03:37 PM
snakeatinZ's Avatar
Cool. That is the one I am going to buy.
Thanks guys,
Steve
Old 03-06-2007, 01:41 PM
snakeatinZ's Avatar
How many bolts do I need to buy from GM? I am going with Part # 14088764.
Thanks,
Steve
Old 03-06-2007, 03:05 PM
mdacton's Avatar
what bolts? its cheaper to get the ARP's anyway
mdacton is offline
Old 03-06-2007, 03:15 PM
snakeatinZ's Avatar
Flexplate bolts. I searched it and found people are having problems with Arp ones. The head on them is too big and does not fit a socket well???
Steve
Old 03-06-2007, 07:33 PM
The Engineer's Avatar
Steve
Yes, that is correct. The large 12-point heads on the ARP flex-plate bolts do not allow space for the socket between the crank hub lip. Get a new set of OEM (GM) flex-plate bolts. Also, use a thread locker and make sure the flex-plate isn't powder-coated.
WD
The Engineer is offline
Old 03-06-2007, 10:16 PM
mdacton's Avatar
ARP came out with new ones that have smaller heads.
mdacton is offline
Old 03-07-2007, 05:19 AM
Moderator
rskrause's Avatar
You realize that this is not an LT1 specific piece but is generic? If you have stock rotating assy., you can buy a flexplate that is a simple bolt on as it is already balanced against a stock bob weight. If it's for the combo in your sig, which looks like a non-stock setup, it is going to need to be final balanced. You probably already know this, just pointing it out to those reading who think the piece would be a simple bolt-on.
Rich
rskrause is offline
Old 03-07-2007, 06:17 AM
snakeatinZ's Avatar
Rich
Rich, whenever you have something to say I am all ears. Over the years you have tought me alot about these cars. My motor has a stock crank, with forged Speed Pro pistons. I need the flexplate for the Machine shop. This weekend they are going to get everthing I have to assemble the long block. oooh happy day!!!!!!
Steve
Old 03-07-2007, 06:38 AM
Moderator
rskrause's Avatar
Steve
Great feeling!
A "generic" flywheel like that will usually have a large balance weight. The machine shop will balance it against your specific assembly by drilling shallow holes in the weight to remove the necessary amount.
Rich
rskrause is offline
GREEN3112
02-10-2019 09:19 PM
Ericksd
01-20-2016 06:07 PM
95blkss
09-22-2015 03:18 PM
Daluchman1974
09-11-2015 06:12 AM
karpetcm
08-14-2015 03:02 PM
Quick Reply: What flex plate???
