What else to add when installing Trans Go Shift Kit
Old Mar 27, 2010 | 05:56 PM
mike445's Avatar
From: Wasaga Beach, ON (formerly Ft. Lauderdale,FL)
I will be having a Trans Go Shift kit (HD-2) put into my 4L60E in the next month or so. What else should I do at the same time? So far I have the following parts:
*Trans Go Reprogramming Kit (4L60E-HD2).
*Trans Go 4L60E Valve Body Plate 1995 Heavy Duty (46-PLT-95).
*Trans Go Corvette Servo Piston 700R4 4L60 4L60E.
*Servo release check valve for the 700R4 & 4L60E.
Is there any other parts I should get? Anything else I should do while I have the above installed? How many spacers do y'all recommend I use? Thanks!
Mike
Old Mar 29, 2010 | 06:40 PM
z28beast's Avatar
Mike
so did you do the install????? how difficult was it? i have the same kit but i didnt buy the servo or the servo release....i did however buy the valve body plate...is there any advantage to the valve body plate?? also how do you like the kit?
Old Mar 29, 2010 | 07:21 PM
mike445's Avatar
I haven't done the install yet. I'm hoping to have it done in the next 2 weeks or so. The servo is supposed to be a great addition too. I got mine off ebay for $20 shipped to my door. The valve body plate we bought has an improved design and is made from tempered steel for longer life and zinc plated to be rust proof. I'll let ya know how I like it when I get it in.
Mike
Old Mar 29, 2010 | 09:06 PM
z28beast's Avatar
Mike
ok cool...thanks alot bud
Old Mar 29, 2010 | 09:44 PM
z28beast's Avatar
Mike
also is this the servo thing you were talking about?
http://cgi.ebay.com/ebaymotors/CORVE...Q5fAccessories
and will i need to install anything else with it?
Old Mar 30, 2010 | 12:29 AM
Pro Built Automatics's Avatar
When you get ready to install this call me and I will walk you through a few things and some other modifications you can do, 909 795-1876. Go to a transmission shop and pickup 8 Torlon 1/4" checkballs from an AOD or AODE transmission. This will keep from destroying the separator plate. Ask for a Viton sealing ring kit for the 2-4 servo. These work much better than the scarf cut teflon sealing rings on the 2-4 servo. DO NOT add any spacers to the 2nd accumulator. With the stock 12" torque converter, drill the 2nd feed hole in the separator plate to .082", with a 10" or smaller torque converter, drill the 2nd feed hole to .093". This will give you something to do for now.
Old Mar 30, 2010 | 10:07 PM
z28beast's Avatar
ok cool man thanks for being so willing to help and so generous with your knowledge....btw i still need to know is that the correct servo to get for the "upgrade" ? btw thanks again for the help also when i call ask for dana rite?
Old Apr 1, 2010 | 11:21 PM
The Corvette servo is an upgrade. If you use the TransGo Shift kit, you will not need the Servo release check valve. I am the only one who answers the phone, and I will help you with the torque converter selection.
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Don 97 SS
Jul 11, 2005 08:50 AM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Aug 27, 2002 12:20 AM
