Transmission Swap *Too tight?*
Old May 4, 2008 | 04:44 AM
theratdude64's Avatar
Putting the transmission back in tonight and all is going well... except one pretty damn big problem The torque converter to flywheel is way too tight. The engine doesnt wanna spin, it seems very pressed together. This is not normal... WTF it should spin Free. Any ideas WTF is wrong?
Old May 4, 2008 | 08:16 AM
Did you get the TC installed all the way, first?
Old May 4, 2008 | 09:21 AM
jay_lt4's Avatar
did you already tighten the bellhousing bolts,, if you did you probly broke the pump already from not having it fully seated in the trans
Old May 4, 2008 | 09:41 AM
12SCNDZ's Avatar
...Converter's not all the way in. You've probably broken the pump already.
Frank
CPT
Old May 4, 2008 | 11:32 AM
it seated on both sets of splines so I duno if its not on all the way or not. Seems like the input is too long on it or something, i duno. Does it have to set 3 times? It deffinatly clicked down over both sets of splines. How can I see if the pump is dead?
Old May 4, 2008 | 12:34 PM
jay_lt4's Avatar
remove the pump and take it apart
Old May 4, 2008 | 01:52 PM
GOT IT, Yey
Old May 5, 2008 | 11:49 AM
pcgamer4life's Avatar
Ran into the same problem probably 5 different times on older GM transmissions (TH350/700r4). For future reference, the key to most GM transmissions is 3 clicks on the torque converter to get it all the way set it.
Old May 5, 2008 | 12:12 PM
Like I'll have to pull stuff out again, It was lookin good but now that stuff is bolted up it wont work. I can't get it down that 3rd click to save my life. Any tricks/suggestions?
Old May 5, 2008 | 02:36 PM
jay_lt4's Avatar
you are going to need a trans shop to pull the pump out and check it now that you have been trying to force it in. i would bet the pump is already broken
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Victor Lamb
Aug 26, 2017 02:52 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
