Transmission Swap *Too tight?*
Putting the transmission back in tonight and all is going well... except one pretty damn big problem
The torque converter to flywheel is way too tight. The engine doesnt wanna spin, it seems very pressed together. This is not normal... WTF it should spin Free. Any ideas WTF is wrong?
it seated on both sets of splines so I duno if its not on all the way or not. Seems like the input is too long on it or something, i duno. Does it have to set 3 times? It deffinatly clicked down over both sets of splines. How can I see if the pump is dead?
remove the pump and take it apart
Ran into the same problem probably 5 different times on older GM transmissions (TH350/700r4). For future reference, the key to most GM transmissions is 3 clicks on the torque converter to get it all the way set it.
Victor Lamb
Aug 26, 2017 02:52 PM
