Transmission Problems, barely moves when starting from a stop
Old Dec 29, 2009 | 09:53 AM
95mustangkiller's Avatar
recently my transmission has started acting up. If i put it into drive or overdrive and step on the gas the car barely moves until i get up to about 30 mph and then it starts to drive normally, except that it makes an odd grinding noise. if i put it into 2nd or low gear then the car will start off normally. Any ideas?
Old Dec 29, 2009 | 09:56 AM
Welcome to CamaroZ28.com!!!
Probably get best results on the "Drivetrain" forum. I'll move your post there, noting that you appear to have an LT1, since you originally posted in "LT1 Based Engine Tech".
You might want to add a "signature" with basic info about your car - year, model, engine, trans, and any major mods.
Old Dec 31, 2009 | 11:54 AM
Performabuilt's Avatar
Supporting Vendor
Not sure about the noise but sounds like pcm is in limp mode i would scan for codes
F'n1996Z28SS
Aug 23, 2023 11:19 PM
PCLZ28
Dec 24, 2015 05:19 PM
HCz28
Jan 11, 2015 11:21 AM
tds1213
Nov 27, 2014 12:55 PM
thenewkid
Nov 27, 2014 09:41 AM
