Trans Shifting Problem-2 Ideas
Old Mar 8, 2004 | 05:29 PM
NoFear95's Avatar
1995 TA, FLP level 4 tranny
If I am cruising around part throttle the 3-4 shift comes in at like 35-39 MPH, then pops back into 3rd and stays until 45ish. If I manually keep the car in 3rd. and shift into OD at 45 there is no problems.
Do you guys think this is a programming issue? Car had Head, cam and programming along with a FLP level 4 all at the same time.
or
Do you think its a shift solenoid issue? Since it will allow me to do it manually I didnt think it was it.
Thoughts trans guru's?????
Old Mar 9, 2004 | 09:56 AM
NoFear95's Avatar
Alright talked to the previous owner and the problem seems to have started after the rebuild. Could it be a shift solenoid? Got a scan master and there are no codes. Could it be sticking?
PCLZ28
Dec 24, 2015 05:19 PM
PCLZ28
Apr 29, 2015 11:56 PM
jb4xx
Feb 2, 2015 10:00 PM
Brake_L8
Jan 20, 2015 09:44 AM
blac94Z
Jan 5, 2015 06:13 PM
