Trans Dip Stick
Old Jul 29, 2009 | 02:50 PM
bqman's Avatar
Trans Dip Stick
Well, I made a boo boo. I pulled the tube that holds the trans dip stick and spilled tranny oil everywhere, I tried to put it back in and can only get it half way through. Theres a rubber stopper of some sort keeping it from pushing all the way in. That and I have other things now in the way as well.
So a question, can I put RTV on the tube that goes into the tranny and will that be enough to hold the fluid in? Remember, the tube is in half way, I just don't want tranny fluid to leak when I'm driving.
Old Jul 29, 2009 | 04:47 PM
n2ceptor's Avatar
You should purchase a new grommet....
Old Jul 29, 2009 | 08:51 PM
rclearyiii's Avatar
Agree
Agree...if you use sealer..and not a new grommet..you will end up with leaks..sooner or later.
Old Jul 30, 2009 | 02:57 PM
bqman's Avatar
How and why is that? The fluid doesn't get that hot and if it works on cylinder heads and water pumps why won't it work on the dip stick tube?
Old Jul 30, 2009 | 04:10 PM
Lol, you asked for opinions and got the correct remedy (apparently not what you wanted to hear) to satisfy "I don't want tranny fluid to leak when I'm driving". You can choose to do something else, but it might not have desired result.
Old Jul 30, 2009 | 07:19 PM
n2ceptor's Avatar
I concur...
Old Jul 31, 2009 | 01:17 PM
bqman's Avatar
I understand it'll leak, I just don't know why. I'll try the new gommet but the tube was hitting my bell housing, engine, firewall...no angle was working for me. How far is it suppose to be pushed in? I think I got it about 3/4" in but then it got stuck.
Is there a particular angle to get it in that I'm just missing?
Old Jul 31, 2009 | 01:46 PM
cause4panic's Avatar
If the dipstick tube is not completly seated it will not give correct readings.
FredM
May 28, 2015 04:28 PM
warmeck
Mar 16, 2015 07:02 AM
Scottylt1
Jan 8, 2015 02:48 PM
Cam's maro
Dec 29, 2014 08:44 AM
Scottylt1
Dec 4, 2014 12:31 PM
