What Gears Does My 95Z have Now?.. Upgrade options?
Old Jul 18, 2009 | 05:23 PM
ENRKyle20's Avatar
my gears now and goofy. I dont even use 6th at all (cam surge wont allow it under 75mph), 1st brings me so high. I would have to guess like 2.73's?..
well I need to get that out of there. I want to feel my power at lower speeds, right now im not in the sweet spot until 35-40mph.. I want that power at 15-20mph!..
So I was thinking 4.10;s?.. What do you think my rpms would be with 4.10's at 75mph in 6th?. think 4.10 is a bit much for a car driven a few times a week, about about 30% highway. ?
how do i find out what series carrier I have? is that the only info I need to order a gear set?..thanks for the help
Old Jul 18, 2009 | 06:52 PM
RUDEDOG's Avatar
You probably have 3.42 gears. At 75 mph and 4.10 gears my rpm's are 2050 in 6th gear.
Old Jul 18, 2009 | 07:08 PM
Your car came with 3.42s.
Use this to track rpm with different gears: http://www.f-body.org/gears/
Old Jul 18, 2009 | 07:19 PM
ENRKyle20's Avatar
wow. I am amazed that these are 3.42. I def think that 4.10's are my answer than that sounds like the kind of r's I want on the highway. right now im at 1650ish.. . and thank you much for the calculator shoe.
(firefox is telling me that this is a reported attack site and blocks it.Oh well. lol.. Even if the site is known safe, In some cases, third parties can add malicious code to legitimate sites, which would cause the warning message.)
Any idea on my class of carrier?.. BTW shoe.. I love you xoxo .. LMAO!.. no really, your a GREAT assist to this site! (and your site is amazing as well
Old Jul 18, 2009 | 07:23 PM
ENRKyle20's Avatar
playing with the calculator I think I may even want a even lower ration (higher number). maybe 4.56?
do they even make that for out diff?.. think that would be overkill for a road car?.
Old Jul 18, 2009 | 10:28 PM
You would have a 3 series carrrier with the stock 3.42 gears. Most people with M6s, opt for 4.10s as the best all-around (still being street driven). A4 people usually go with 3.73s.
Old Jul 19, 2009 | 06:39 PM
ENRKyle20's Avatar
ok thank you, I think thats what I will do. are all gear sets created equal? The diff is still going to be a weak point correct.
Old Jul 20, 2009 | 05:14 PM
People like to say that Motive gears are quieter, Strange gears maybe a little less and Richmond noisier, but perhaps stronger. All will be at least as strong as stock. As far as noise goes, that is up to the installer. A good install can make any of these quiet (and they should be).
Old Jul 23, 2009 | 01:53 PM
mvvette97's Avatar
automatic?
are 4.11 gears too much for an automatic stock transmission for a 97 z28?
Old Jul 31, 2009 | 11:11 PM
94zgreenmachine's Avatar
4.10's on a Dana S60. At 75 mph I am close to 3K rpm. Not too bad but ya better get use to the exhaust humming.
If you want a better ride try this: No radio, Longtubes, no cat, magnaflow cat back. All poly suspension, upper and lower sperical rod ends instead of poly bushings, I don't think I could drive this thing more than 50 miles at a crack..... or maybe I am just getting older......
Old Jul 31, 2009 | 11:41 PM
Some would say so, yes. Re-read post #6.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
Jul 4, 2005 05:00 PM
