TH-350 question
TH-350 question
Greetings!
I have a question regarding my tranny (TH-350). I’ve already installed TCI Master Racing Ovehaul kit, B&M transpak shift kit and Adjustable Transmission Modular Valve. How can I set this gearbox to change gear upwards at aprox. 6000+RPM and not at 5500 like it does now.
My engine configuration is as follows:
Engine:
Chevy SB 383 stroker, Edelbrock RPM AirGap dual plane intake manifold, Dart Iron Eagle Heads with int:2.02 exh:1.60, roller rockers 1.5:1 ratio, carb Mighty Demon 825, Cam: CompCams Extreme Energy XE274H (duration @050: in:230, ex:236, lift in:.490, ex:.490), full length Hooker Headers, HEI ignition, forget pistons, forget crank, forget connection rods...
Tranny: TH-350 with TCI Master Racing Overhaul kit, B&M transpak shift and Adjustable Transmission Modulator Valve, B&M Holeshot 2400 Torque Converter
Rear end: GM 10 bolt, 3.23 gear ratio, Auburn gear Pro series LSD
Looking forward to your kind answers and thank you for your time...
_BANDIT_
Engine:
_BANDIT_
Re: TH-350 question
The TH350 is governor controlled. Lighter weights and/or lighter springs in the governor will make it shift later. It's a "hit and miss" thing...I'd suggest only going a little at a time. 500 RPM difference should only require putting a lighter spring in place of (1) of the heavier ones. B&M sells a weight/spring kit.
Frank
Frank
Re: TH-350 question
I installed the B&M Governor Recalibration Kit in my TH350, and I love it. I can't remember which parts I installed, but I got the shift points to be between 6200 and 6300rpm right off the bat. I can go back and figure out which weights and springs I put in if you like.
Re: TH-350 question
Frank
Frank
_BANDIT_
Re: TH-350 question
_BANDIT_
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
