T-56 Transmission Fluid?
Old Jul 15, 2013 | 12:23 PM
boomtufo's Avatar
Hello everyone, I am inquiring about the best type of transmission fluid you can use in a T-56 Trans.
I need to change my fluid and want to put the absolute best I can in it.
On the trans case it says only use Drexon or something like that.
I'm wondering if there are better alternatives.
Thanks!
Old Jul 15, 2013 | 12:47 PM
timnfxr's Avatar
Re: T-56 Transmission Fluid?
I use Mobil 1 Synthetic ATF.
Old Jul 15, 2013 | 03:06 PM
The Borg-Warner/Tremec (manufacturer) recommendation is Dexron III ATF.
From the Tremec website FAQ:
Q: Why not use a synthetic fluid?
A: Some brands of synthetic fluid contain powerful detergents and additives that can prove harmful to your transmission's synchronizers. While many synthetic fluids perform very well, in most cases, we do not recommend their use. Furthermore, they may void your warranty. For peace of mind, remember that TREMEC conducts all of its OEM validation testing using conventional fluids without issue.
Frequently Asked Questions (FAQs)
Moving to "Drivetrain" forum.
Old Nov 12, 2014 | 02:46 PM
Starion's Avatar
Question Re: T-56 Transmission Fluid?
The above info is not clear as it refers to automatic TREMECs.
What is the best trans ATF for the T56 Manual 6 speed?
Same issue about synthetic?
Old Nov 12, 2014 | 05:48 PM
The Tremec FAQ linked above is SPECIFIC to the Borg Warner and Tremec T56 6-speed MANUAL transmission. With regard to synthetic ATF they SPECIFICALLY state that it can damage the synchros.
How did you determine that info applies only to Tremec automatics?
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Dec 30, 2015 09:55 PM
raroz28
Sep 8, 2015 06:10 AM
dolfan324
Jul 17, 2015 10:34 PM
Noct
Jul 14, 2015 01:18 AM
