T-56 question
Old Mar 26, 2007 | 08:38 AM
slow94z28's Avatar
T-56 question
My t-56 is leaking fluid from the rear where driveshaft goes in i changed the seal and still leaks and when driving it vibrates like a mother some one told me that there is a bushing in the tailshaft that is probobly busted.Any one know anything about this, is this the problem.If so where can i get the bushing? How hard to fix?
Old Mar 27, 2007 | 10:35 PM
95Blackhawk's Avatar
There are 2 rubber rings inside of the driveshaft seal. They are grooved so that the will sling oil back into the case. I had a leak also and what I had was a broken rubber ring. Siliconed it back together and no more leak.
Ben
Old Mar 28, 2007 | 09:47 PM
EKO's Avatar
EKO
I had the bushing go on me too. Turns out its pressed into the tail housing and I ended up buying a new one as per the advice of a person more knowledgable than I. No more leaks.
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Duke
Jul 31, 2002 05:13 PM
