Shattered Input Drum??
Old May 13, 2008 | 11:38 AM
redfirehawk101's Avatar
I just got back from my local tranny shop to look at my internals on my tranny. Come to find a shattered input drum and the input shaft had metal pieces missing as well on the end. Any ideas on how this could have happened and what parts to use on a rebuild. The guy working on the tranny has never seen this before on the 4160e transmission. Any thoughts?
Old May 13, 2008 | 11:47 AM
12SCNDZ's Avatar
Is your Vigilante a multi disc converter? Are you locking the converter at WOT?
Frank
CPT
Old May 13, 2008 | 12:02 PM
It is a single disc converter and the computer should be locking the converter at WOT.
Old May 13, 2008 | 04:38 PM
Performabuilt's Avatar
Supporting Vendor
There could be any of several reasons, The drum could have just been weak and gave way, Theres the possibility that your PCM is allowing lockup during shifts. This is very hard on the drum regardless of throttle position, But its likely the first scenario. I would replace the drum and shaft and then have your tuner set up so your car can only lock the converter clutch in 4th gear above 40 mph and never at WOT .
Old May 13, 2008 | 06:59 PM
predator's Avatar
obviously your builder hasnt done to many performance units if he has never seen a shattered input drim
Nayr
Mar 3, 2023 08:34 PM
Ericksd
Jan 20, 2016 06:07 PM
marlar98
Oct 21, 2015 02:02 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
