0 degree pinion angle
Old May 12, 2008 | 01:53 PM
luckyou03's Avatar
I just checked my driveshaft and it's -7 (front end was jacked up, rear tires on the ground) and the flat spot on the bottom of the torque arm bolted to the rear end is -7(front end was jacked up, rear tires on the ground). My pinion angle is 0. What are the negative affects of this angle? It's suppose to be 2 to 3º or -2 to -3º?
Old May 12, 2008 | 04:24 PM
slowride94z's Avatar
I'm going out on a limb here, the drive shaft has nothing to do with your pinion angle, and shouldn't be an issue unless your talking about a 4x4 camaro with a lot of lift.
the measurements you need are the bottom of the body and the pinion angle, the pinion should be pointing toward the ground -2* from the body's line or sub-frame connectors
some idiot had a very crude drawing recently do a search for "torque arm issues"
good luck hope this helps
Old May 12, 2008 | 11:30 PM
While, in theory you need to verify that the centerline of the tranny is parallel with the centerline of the pinion shaft, that not really necessary, unless you've somehow altered the way the engine sits in the chassis. Its generally adequate to measure the driveshaft angle, measure the pinion shaft angle, and make sure they form a slight "\/" with the nose of the pinion shaft pointing down one to three degrees relative to the driveshaft. That way, under heavy load, when the nose of the pinion shaft kicks up in response to heavy torque loads, the pinion shaft and the driveshaft will be straight, minimizing loads on the U-joint. The instructions from the manufacturers like Spohn recommend this procedure.
Why would you call someone who tried to help with setting up the torque arm an "idiot"? Was the information incorrect?
Old May 13, 2008 | 08:09 PM
It was me, myself, the idiot who did the "non" artist drawing or rendering
just poking fun at myself no harm no foul
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
13qtr
Jul 19, 2015 05:30 PM
