Rear axle/differential question
Old Jun 18, 2009 | 08:08 AM
Patman69's Avatar
I have a 1984 Z28 with the a 10 bolt cover/26-spline/7.5" dia./3.73 ratio rear end assembly (the stock arrangement). I need a new ring/pinion gear set and also wish to upgrade the other comonents as well. I plan on using a Detroit TrueTrac or Auburn Mfg. differential (they both make a gear driven model which reads as very reliable). I also believe I would like to upgrade to 28-spline axles as I have recently upgraded the motor/tranny from stock.
My question: 1) Will this setup work using the same rear end housing I currently have?
Thanks.
Old Jun 25, 2009 | 10:54 PM
mr.green's Avatar
might want to post in the correct section...you should have better luck with your question.
oldschool
Feb 9, 2016 09:21 PM
Patricklt1
Apr 24, 2015 06:29 AM
Jan 13, 2015 09:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
FiNSTa
Jul 20, 2002 10:57 PM
