Problem setting proper backlash with Motive 4.11
Old 06-04-2008, 04:36 PM
Style's Avatar
First off, the shims that come with the kit are .010, .012, .016, .020?? Would be helpful if there was a .014
After setting proper carrier bearing preload (so the carrier has to be gently "tapped" in), I cannot get the backlash within spec with the shim combinations possible. I am getting either ~.0076 or ~.0128 and nothing in between. (Motive spec is .008-.012)
So should I back off the preload and reset the backlash, or use the .0128 value?
Here are some pictures with the marking compound at ~.0128.
The pinion depth looks good, at least comparing it to the Motive pattern example. The GM Service manual recommends a centered pattern, though.
http://i131.photobucket.com/albums/p...e/IMG_1180.jpg
http://i131.photobucket.com/albums/p...e/IMG_1181.jpg
http://i131.photobucket.com/albums/p...e/IMG_1182.jpg
Style is offline
Old 06-04-2008, 06:37 PM
Kevin Blown 95 TA's Avatar
That pattern looks slightly in to me, but I would use the 7.6 thou backlash and not worry about it. I dont understand why you cant get what you want with those shims, though.
Kevin Blown 95 TA is offline
Old 06-04-2008, 06:52 PM
Style's Avatar
Thanks for the reply. The problem I have is the preload feels great, but with that preload, I cannot seem to find the right combination of shims to bring it into spec with that preload. Perhaps I will go with the .0076 measurement. I will try that later with the compound to see where I am at.
Style is offline
Old 06-05-2008, 07:27 AM
cause4panic's Avatar
Pinion depth is too tight, add more shims. If necessary you can buy more shims off summit or jegs. Do it once DO IT RIGHT
cause4panic is offline
Red Hawk 94
03-18-2019 04:03 PM
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
ddr698
01-09-2015 10:05 AM
Britbilly
01-07-2015 08:49 PM
Quick Reply: Problem setting proper backlash with Motive 4.11
