Noob question
Old Mar 11, 2010 | 01:56 AM
maliveline's Avatar
Noob question
So I'm allowed 1 noob question a week right? So... does a stock 1993 z28 have a limited slip differential? Just out of curiosity when did they switch from limited slip differentials to traction control? 1996? The only information I found was in my chiltons manual. It said there was suppose to be some tag on the axle cover plate. I looked under my car last night and all I could see was rust and no tags anywhere. I've searched the net and surprisingly there is not really any information.
Old Mar 11, 2010 | 05:07 PM
ALL 4th Gen (93-02) V8 F-Bodys have a limited slip differential. There is no tag on the differential. Look for RPO code "G80" on the build code tag.
Traction control (RPO "NW9") was made available as an option starting in 1995. It does not replace the limited slip differential. In simple terms, it can cut power and apply brakes to keep the wheels from slipping. Not the things you want to do when attempting wide open throttle acceleration. Typically, you turn traction control ("TCS" in the Firebirds, "ASR" in the Camaors) off when you race.
Old Mar 11, 2010 | 09:07 PM
maliveline's Avatar
thanks man your the best. im planning on changing my differntial fluid soon just wanted to make sure i get it right.
Old Mar 12, 2010 | 09:19 AM
You need the correct lube - SAE 80W-90 GL5, plus 4 ounces of GM limited slip additive (PN 1052358).
Old Mar 12, 2010 | 11:02 AM
maliveline's Avatar
can I use synthetic if I want to?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
