Need Help Removing T56
Old Oct 13, 2004 | 09:43 PM
wonbadassz28's Avatar
i have a 96 Z28 with a T56 and need to replace the clutch, i have disconnected EVERTHING from the trans and it will move freely to a certain point it seems as though its hitting the floor boards before i can drop it the whole way down, anyone have this problem or know or can help me get this thing out i would like to fix it tomorrow night, thanks
russ
Old Oct 13, 2004 | 09:50 PM
Fast Caddie's Avatar
Re: Need Help Removing T56
did you pull the clutch fork off the TO bearing?
Old Oct 13, 2004 | 09:57 PM
well i took the slave cylinder off and the housing around the end of the fork and pulled it as far as i could, i couldnt get it the whoel way out, or does it need to come the whole way out, i felt it click out of the bearing
Old Oct 14, 2004 | 12:54 AM
The slot in the fork is about 1-1/4" long. That's as far as it will move, and that is enough to get it clear of the T/O bearing. If the tranny is actually hitting the floor, push up gently on the front of the engine to tilt the tranny down. A block of wood under the damper will work.
http://cjcfo.fbody.com/members/injun...C/DCP02754.jpg
Old Oct 14, 2004 | 08:25 AM
GREGG 97Z's Avatar
Do you have the engine & trans supported or did you let it hang? My mechanic buddy whose done a lot of these told me it's fine to just let it hang by the motor mounts unsupported, it makes it a lot easier to access some of the hard to reach bolts and gives you more clearance when removing it. Thats how I pull mine now, it comes out no problem that way.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Jul 10, 2015 06:29 PM
birdblack
Jul 8, 2015 07:23 AM
cmdeshon
Dec 27, 2014 10:06 AM
