Need Help Removing T56
i have a 96 Z28 with a T56 and need to replace the clutch, i have disconnected EVERTHING from the trans and it will move freely to a certain point it seems as though its hitting the floor boards before i can drop it the whole way down, anyone have this problem or know or can help me get this thing out i would like to fix it tomorrow night, thanks
russ
russ
Re: Need Help Removing T56
well i took the slave cylinder off and the housing around the end of the fork and pulled it as far as i could, i couldnt get it the whoel way out, or does it need to come the whole way out, i felt it click out of the bearing
The slot in the fork is about 1-1/4" long. That's as far as it will move, and that is enough to get it clear of the T/O bearing. If the tranny is actually hitting the floor, push up gently on the front of the engine to tilt the tranny down. A block of wood under the damper will work.
http://cjcfo.fbody.com/members/injun...C/DCP02754.jpg
Do you have the engine & trans supported or did you let it hang? My mechanic buddy whose done a lot of these told me it's fine to just let it hang by the motor mounts unsupported, it makes it a lot easier to access some of the hard to reach bolts and gives you more clearance when removing it. Thats how I pull mine now, it comes out no problem that way.
ducttape1975
Jul 10, 2015 06:29 PM
