M6 would barely shift into 1st or 2nd; found out why
Old Feb 27, 2009 | 07:56 PM
blue's Avatar
The pin in the shifter was off center. I had to jam it into 1st and second sometimes. I took the shifter off and noticed it would go to the reverse side fine, but would barely move over to the 1st side at all. I took it apart: there are two hemispherical plastic pieces the shifter sits on with a pin through both and through the shaft in the middle. The pin was over to one side too far. This is off a 96 SS. The shifter off the '94 z28 was a lot different, you couldn't take that one apart, and instead of coil springs to hold the shaft in the middle, it's a bent metal plate spring.
As far as I know the '96 shifter is stock. There is no Hurst or any other stamp on it anywhere. Which makes me wonder how the pin got off center. Apparently Chevy changed the shifter design dramatically between '94 and '96, and also apparently someone at the factory messed up the assembly.
Problem now documented onto camaroz28.com.
Old Feb 28, 2009 | 09:24 AM
95zsean's Avatar
NICE!!!!! I wonder if other people having shifting problems and blaming it on the clutch should look at this first.
Old Mar 1, 2009 | 07:08 PM
blue's Avatar
Yea, it's a funny problem. The kind of thing you would never think of, and the kind of thing you would never find anything on with a search.
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
DarkHorse
Aug 3, 2002 10:17 PM
simple
Aug 2, 2002 03:30 PM
HuJass
18
Jun 24, 2002 09:19 PM
