Does the Street Twin require a special throwout bearing?
Old Mar 21, 2009 | 11:00 AM
JP95ZM6's Avatar
My LT1/T56 with a couple thousand on the new street twin is squealing during shifts, so I think I need a new T.O. bearing already. McLeod wants around $250 for a replacement! Is theirs special somehow? Will a stock GM T.O. bearing work instead?
If stock works, is a dealer part the best bet, or what?
Thanks, guys.
Old Mar 21, 2009 | 11:28 AM
userchemical's Avatar
here is a McLeod
here is stock, well centerforce
do you already have a mcleod in? twin clutches usually require more pressure so that explains the beefed up T.O. Bearing.
Old Mar 21, 2009 | 11:45 AM
JP95ZM6's Avatar
Thanks, but you showed the Mcleod HYDRAULIC throwout bearing used for push-style clutch conversions, such as in their old-style LT1 kit, IIRC.
I have their traditional style one that came with my new-style Street twin. That setup retains the factory hydraulic slave cylinder and uses the stock fork to move the TO bearing with normal, pull-type action. My McLeod bearing looks like a stock TO bearing. But, I don't know it the length is the same, or if it is upgraded somehow, and don't really want to pull the clutch before I have parts.
My searching found conflicting statements - some had been told the McLeod uses stock TO and pressure plate, but the McLoed site mentions 'angular contact for better durability'. I'm hoping for a good alternative from someplace else. After waiting several mos to get my clutch kit and then finding it had no holes in the flywheel, and waiting 1 year+ for the master cylinder, I'd rather not deal with McLeod for any orders if not absolutely necessary.
Old Mar 21, 2009 | 02:13 PM
Not in LT1 Based Engine Tech...... Moving to "Drivetrain"
Old Mar 22, 2009 | 10:46 AM
JP95ZM6's Avatar
Sorry, and thanks.
MyfateZ28
Jun 19, 2015 03:42 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
BPS
9
Mar 5, 2015 10:51 PM
Ringmaster72
Feb 25, 2015 03:15 PM
RichJ
Aug 11, 2002 10:14 PM
