Dana 60 Owners
As I recall, the stock 10-bolt was within 10# of the Strange 12-bolt. I weighed them both and was surprised how little difference there was.... but it was 8 years ago and I don't remember the exact number.
Somone asked me for a reference to the National Dragster issue that had the info on the losses..... it goes back at least 5 years. I have it somewhere in a pile of articles I tore out of the magazine and saved. I'll post the issue date when I find it.
I have an s-60 in my 02 formula, i just put it in 3 weeks ago. it went in with no problems at all. strange really thought of everything as far as swapping it out to stock placement. mine even came with brackets welded on for rear sway bar. as far as power loss I haven't seen any loss at the track. if anything the extra weight on the rear tires has helped my car launch better. so far i have a new best with this rear on motor 1.5 sixty foot 11.6 @114 mph. I did buy it through vengance racing. it was cheaper to go through them instead of going to strange direct.
My best 60ft is 1.61 with 11.30s. However, I currently have 3.73s and small 26" tall ET Streets. I'm planning to go to a Moser 12-bolt w/ 4.30s and 28" x 11.50 slicks and hope to have 1.5 60ft times with that new combination. Also, more consistent launches.
WD
So, in the classic dispute ford 9" or 12 bolt Gm, The Dana 60 is better all the way around? How about fitment as well as brake accomodations? I just blew out the stock 10 bolt and need a new rear end... I have big plans for the car, so, I figured I would go with the rear end able to handle the most... like I did wit h my clutch... thanks
I was hoping that the shipper invoice would have the weight on it. The bad thing is if it did it wouldn't be close. Strange bolts it to a big pallet and has it enclosed in a seriously thick cardboard box. I bet the weight of the packaging is well over 50lbs. The shipping co usually takes the entire pallet and throws it on a scale.
That 1.5 60ft time is "really good" for the 11.60 ET. What gear ratio and slick size are you running? Also, is you car an auto, or manual?
WD
WD
my car is an auto, 26x10.5 mickey thompson et streets, 4.10 gears. I do have nitrous but i haven't sprayed it yet since I've done the rear, converter, and tranny. my sixty foot to be exact was 1.53
WD
I can't wait to get to the track on jan 5 to pay better attention at the rpm. I never seem to check it and always think about it before or after a run. I know it was about 6k the one time i glanced at it, but I plan to pay better attention the next time out. the converter is a vig 3200. i do wish i would have gone with the 26x11.5 et streets. I was also thinking of moving up to the 28x 11.5s but i'm not sure for now. I can tell you with the current set up the car was still pulling at the trap, how close to the limiter? i don't know cuz I'm a dumb *** that didn't look at the rpm.
With my 3.73s and the 26" x 11.50 ET Streets I'm showing 6100 trap RPM on the factory tach, however, that is probably only 5950 actual (factory tachs are typically 150 RPM high). Therefore with your 4.10s and 26" ETs, you should have about 6350 on the factory tach (6200 actual).
Next season I'm going to a Moser 12-bolt w/ 4.33s and the larger 28" x 11.50 slicks (possibly the new Goodyear slicks). With that combination, my trap RPM should be around 6400 to 6500 (actual). Additionally, the 28"s should make my launches much more consistent. That is currently a problem with my bracket racing (inconsistent off the line).
With the 4.30s and 28” slicks I hope to get my 60ft times down into the low 1.50s which will also improve my ¼ mile ET (possibly 11 teens). My current 11.34 and 11.40s was during T-n-T with poor launchs.
WD
That is a concern of mine which may cause me to go with 28s. I haven't even tried to stall mine up on a launch. i've always launched at idle 850 rpm. I always bracket race and will have to see how well this tire and rear set up work.
Based on your current 60ft and ¼ mile ETs, I bet your car with 4.10s would be “much more” consistent with the larger 28” x 11.50 slicks, or ET Streets. With the small 26” ETs when I have a 1.60 60ft, I’ll run an 11.30, however, when they don’t hold I’ll have a 1.80 60ft and run in the high 11.50s.
What do you think about my proposed 4.30s and 28” x 11.50 for next year?
WD
I have had mine since they first started making them (back in February/March of last year), I beleive beginning of April '06 to be exact...
I got mine with the Powr-Lok diff, 3.56 gears (or was it 3.55), chromemoly yoke, standard metric studs and 3-channel ABS... Installation was quick and painless, except for the torque arm, but that was due to going with the S&W Racecars setup...
For pics:
http://www.darklogic.net/S60-SWRacecars/index.html
http://www.darklogic.net/S60Painted/index.html
I went with the gear ratio that I did because I am supercharged...
For pics:
Formula Steve
Sep 19, 2023 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
