checkin gear ratio
Old Sep 8, 2007 | 01:06 PM
95LT1conv's Avatar
checkin gear ratio
I was trying to check the ratio of my gears today to actually verify that the guy I bought the car from had 4.10's installed. Rotated the tire 1 full turn and got 4.25 turns on the driveshaft. Sound right? tire size, if it matters, is 255/50/16.
Old Sep 8, 2007 | 08:13 PM
95LT1conv's Avatar
anyone?
Old Sep 9, 2007 | 06:53 AM
rskrause's Avatar
Moderator
Well, if they were 4.10's you would have seen 4.1 turns.
Rich
Old Sep 9, 2007 | 05:58 PM
He's within 3-4%... not bad considering the method used. Next option is to pull the cover off and count the teeth.
Old Sep 9, 2007 | 10:11 PM
95LT1conv's Avatar
Thanks guys. I was just hoping NOT to get 3 or so turns of the DS. At least I know something was installed like I was told.
Old Sep 11, 2007 | 01:38 AM
Bayer-Z28's Avatar
A trick I learned.. .It'll give you a rough guestamite.. provided you have stock diameter tires too.
do 80 in 4th gear.. then look at your tach, whatever the reading is is your rear ratio..
(a rough estimate.)
HarleyZ28
Oct 5, 2015 06:23 AM
anmar A
May 2, 2015 06:59 PM
thenewkid
Apr 12, 2015 07:42 PM
Jul 4, 2005 05:00 PM
