checkin gear ratio
checkin gear ratio
I was trying to check the ratio of my gears today to actually verify that the guy I bought the car from had 4.10's installed. Rotated the tire 1 full turn and got 4.25 turns on the driveshaft. Sound right? tire size, if it matters, is 255/50/16.
A trick I learned.. .It'll give you a rough guestamite.. provided you have stock diameter tires too.
do 80 in 4th gear.. then look at your tach, whatever the reading is is your rear ratio..
(a rough estimate.)
(a rough estimate.)
Jul 4, 2005 05:00 PM
