c clip eliminator or not?
Old Jan 8, 2006 | 11:06 PM
moserman's Avatar
im building up my own rear right now, and i cant decide to use the c clip eliminators or not. i know that they strengthen it by a great length, btu i am on a budget build. i need some good input, please help!!
Old Jan 9, 2006 | 07:36 AM
Re: c clip eliminator or not?
Ever see a car launch hard, and the rear axle come spinning out of the housing..... I have. NHRA requires c-clip eliminators on aftermarket axle setups. The c-clip eliminators prevent the axles from coming out of the housing. Break a clip, and there's nothing else holding the axle in.
Old Jan 9, 2006 | 08:00 AM
rskrause's Avatar
Moderator
Any powerful car using sticky tires needs C-clip eliminators. It's a basic safety measure. WRT what Fred said, the only thing keeping the accidents involving broken C-clips from being horrendous is that they tend to happen right near the starting line. But at the very least, a lot of damage is done and there is certainly the potnetial for major injury as well.
A stock or stockish car driven normally on the street doesn't need 'em, a car gaced on sticky tires does. And they aren't a bad idea on a powerful street car.
Rich
Old Jan 10, 2006 | 01:17 AM
moserman's Avatar
well the disk brakes would be holding the axles in if they did break but i guess the next research to find out is will the c clips fit inside an eaton locker? ive ordered the locker with gm factory 4.10's and am waiting to decide about the c clip kit bc i need to kno wether to buy it or not due to the moser axles i want. but im running a 315 nitto drag radial right now and the car is running 12.6 @ 109 with 3.73's and a stock rearend so i suppose it would be a good idea
Old Jan 11, 2006 | 07:38 PM
mourningyou's Avatar
how hard it is to install a c-clip elimination kit? is it at a bolt on level or will special tools be required?
Old Jan 12, 2006 | 07:16 AM
89385formula's Avatar
I have never used a C clip emiminator on another car that came with C clips, But I have seen what it takes to do so, and I can say that on my 9" the axle retention is done by the backing plates we already use. So I would say the only thing special you would need to eliminate the C clips is a different setof axles, then you would slide your backing plates down on them, and press on the axle bearings.
IndyZman
Oct 22, 2015 02:17 PM
surreybrad
Sep 29, 2015 09:00 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
ZXXVIII
Sep 1, 2015 10:13 PM
