BULLET PROOF 10 BOLT? You be the judge!
Trying to get homework done
Kind of new at this, so trying many things, and many things fail, but its fun anyway. The information I am getting from here is amazing, and great insight.
I have 87 Monte Carlo SS, stock 10 bolt 3.73. The stall is 1700 for the 700r4, and considering going higher. I would guess the 383 stroker puts out 400 hp.. (not tested, someone else built the motor). I am actually a bit disappointed in the launch. I figure this would be a great start for something better? I am considering swapping old rear for a 2002 Camaro rear end, Posi 3.73 gears.
Any input would appreciated.. Not even sure if I am in the right place
The F-body rear axle is not a direct swap due to the different suspension designs. While both are "10 bolt" axles they are completely different, and the F-car axle has a smaller ring gear and is inherently weaker than your G-Body 10 bolt. HTH
Gomonty, the rear in your Monte Carlo is not weaker than an F-body rear nor is it stronger. They are the same rear internally. They differ in width and mounting, but the same 7.5 ring gear, etc. You need an 8.5 rear, which came in the Turbo Buick and the Hurst Olds. They will bolt in to your car. It would be the simplest solution.
Re: BULLET PROOF 10 BOLT? You be the judge!
love the easy upgrade. great mod for the money
found this for a nice tie in on the thread
http://www.lpwracing.com/p_axletubebrace.asp
i have a 10 bolt with lpw cover and arp 4 bolt main caps/welded brace kit. have been spraying 250 shot out of the hole for over a year no problem will be going to a 300 shot later this year.
I did a lot of research on axles and found that a full competition axle will not live on the street due to the brittle forging process so I ordered up a set of Moser Street/Strip axles. Then came the center section. Found that there are two different carrier sections for the 10 bolt 7.5 and the stronger of the two is the 2.32 carrier section and also requires a thinker ring gear (more durability!) I optioned for the Richmond gears (ratio of you choice), Richmond Powertracs locker, and Richmond master bearing kit. I installed the Moroso bolt in stud kit.
Richmond gears tend to be noisy. Motives are good, and essentially oem.
