another six-speed question
Old May 25, 2005 | 07:50 PM
cabe_z28's Avatar
there is a faint "clunk" noise from under the car when i row between gears with the clutch pedal pushed in. this only happens when i am slightly rolling at about 3 to 5 mph.
when i am stopped completely, the noise goes away.
it feels like it is having trouble going into gear easily. this is why i posted my other thread about changing tranny fluid.
any help would be appreciated.
Old May 25, 2005 | 10:21 PM
OBE1 95Z28's Avatar
Re: another six-speed question
The clunk could be coming from worn U-joints. U-joints would not explain why you're having trouble getting in gear. Also check you clutch fluid level.
Old May 26, 2005 | 06:46 AM
teke184's Avatar
you're saying when you have the clutch in, and keep it in...and go through the gears...you hear the clunk?
i would say that is just the synchros and gears meshing.
now if it was a clunk on every shift...i would say tranny mount, LCA or torque arm mount
Old May 26, 2005 | 05:14 PM
cabe_z28's Avatar
yeah, it makes the clunk sound every time i go to another gear, while holding the clutch pedal in. and the clutch fluid level is fine.
Old Feb 17, 2006 | 01:35 AM
DuronClocker's Avatar
Anyone know what this is? I'm having the same problem. My car has 110k miles on it, so I'd suspect the syncros are wearing out and making more noise and making gears a bit hard to go between, but that doesn't really explain why this noise is only there when I'm moving slowly. Like the original poster, if I'm stopped, there is no noise.
Old Feb 18, 2006 | 11:40 PM
DiabloGT's Avatar
is it my u joints if i did these mods in my sig and when i floor it form stock or sometimes like it randomly does that loud clunk sound?
thanks
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
