8.5" 10 bolt source FYI
Old Jan 17, 2006 | 11:29 AM
31coupe's Avatar
While searching for a reasonably priced rear end up grade for my g-body project, I found out that you could get a 30 spline 8.5" 10 bolt in the 96 up s-10 V6 blazers. The 2wd's are 54" wide the 4wd is wider (58" I think) & the ZR2 option was even wider. They are all available with 3.42's & the ZR2 was available with 3.73's. Because of the upper mounts they won't work for me, but they should not be too hard to adapt to an F-body.
This is all from what I read so measure & verify before you buy.
Old Jan 17, 2006 | 12:45 PM
MyShibbyZ28's Avatar
Re: 8.5" 10 bolt source FYI
Do they have a torque arm mount? LCA mounts? spring perches?
Old Jan 17, 2006 | 01:25 PM
31coupe's Avatar
No, they are setup for leaf springs, but a decent fabricator would be able to adapt it.
Old Jan 17, 2006 | 11:40 PM
blownxtreme's Avatar
be careful not all are 3.42 and not all have a posi, i got lucky my 2000 s-10 came with an 8.5 rear but with 3.08 gears and an open diff. it is hit or miss finding them and usally they are a little pricey, the zr2's are the widest. and would most likely work the best on an f body.
Old Jan 18, 2006 | 12:20 AM
How wide is the f-body axle? I thought it was around 54" or something.
Old Jan 18, 2006 | 07:07 AM
limige's Avatar
i'm running a late 70's early 80's 8.5" 10bolt that someone welded the tq. arm brackets and lca's stuff... let me tell you, that is a nice heavy duty setup!
Old Jan 18, 2006 | 07:23 AM
How much did it cost you to get the needed stuff welded?
Old Jan 18, 2006 | 05:02 PM
Dave '97 Z28 M6's Avatar
The ZR2 8.5" rear axles (at least the later ones) were all 3.73's with an Eaton locker.
Victor Lamb
Aug 26, 2017 02:52 PM
VF-124
Mar 16, 2015 08:14 PM
maybe2fast
Mar 16, 2015 09:45 AM
mikey4play
Mar 15, 2015 11:45 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
