4L60E Replacing the Pump???
Old May 6, 2005 | 12:22 PM
Red on Red WS6's Avatar
Question 4L60E Replacing the Pump???
I was wondering if anyone can tell me what is holding the transmission pump in, I have unbolted the bolts in the front. I think there is a solinod holding it in there but I don't know where it is at. I am trying to replace the pump outer seal.
Old May 6, 2005 | 12:32 PM
Re: 4L60E Replacing the Pump???
Also what other gaskets or seals do I need to replace besides the pan gasket?
Old May 7, 2005 | 12:31 PM
Has anyone ever put in a trans go reprograming kit?
Old May 7, 2005 | 04:02 PM
Z28 Performance's Avatar
You need to remove the solenoid, and you also need a special tool to remove the pump.
However, you can do it without that tool by using a screw driver between the pump and the input drum and pry on it. For the gasket, I would recommend buying a complete gasket kit and it is about $20. Finally, are you having difficulty to install Trans-go kit? Let me know. Ivan
Old May 7, 2005 | 11:37 PM
Well I put the trans go kit in about 7 months ago and everything went great except for the booster valve because I did not know how to get the pump out, but I did loosen the pump bolts and lightly pulled on it. To make a long story short it I ran out of time put it back together and it leaks about 1Qt a month from the pump o-ring. I am in the process of other mods and I now have the tranny out. Do you by chance know where the solinoide is located?
Your help is greatly appricited.
Old May 8, 2005 | 10:08 AM
12SCNDZ's Avatar
Um...You don't have to remove the pump to put the boost valve in. You can get to it from the bottom of the transmission.
You have 2 things keeping the pump in...The lock-up solenoid, and the filter. Both are easily removed if you pull the pan.
The lock-up solenoid is in the pan. It's held in by 2 10MM bolts. If yours is a '95-up, you'll want to remove the PWM solenoid that's sticking out the front of the valvebody (directly over the Lock-Up solenoid. This can be done by removing the retaining clip in the slot in the valvebody, with a small screwdriver. Be careful the clip doesn't fly away on you.
Frank
Old May 8, 2005 | 03:17 PM
Frank
That is exactly what I needed to know thank you very much.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
