4.11 gear ?
Old May 19, 2004 | 05:41 PM
whiteslpz's Avatar
4.11 gear ?
I'm going to get 4.11 gears, where did you guys get them from.
Jason
Old May 20, 2004 | 08:04 AM
importeater's Avatar
I got mine from Drivetrain Specialist 1-800-216-1632. They are Sierra Gear. Ask them to go back an count the teeth because all there brands are marked 4.10-4.11.. some are 4.10 some are 4.11, you want 37 ring 9 pinion. Sometimes Motive gears are 4.10's sometimes 4.11's depends on where they were made. I dont have any problems with mine, they wine a little like Richmonds but not bad, I also had mine installed a little tighter since its not a daily driver and I wanted a little stronger for the track.
Craig
Old May 20, 2004 | 08:41 AM
rncotton's Avatar
I got a set of Motive 4.11 gears from a local shop for $150.
If I recall correctly, if you get Motive gears, the ones made in USA are 4.10, and the ones made in Italy are 4.11.
Old May 20, 2004 | 08:58 AM
unvc92camarors's Avatar
what's the difference between 4:10's and 4:11's?
i tried a search and didn't come up with anything so...
Old May 20, 2004 | 01:01 PM
1984camaroz28's Avatar
yea i also got mine from a local vendor and me an my dad put them in
Old May 20, 2004 | 01:03 PM
the .01 I was red something a few weaks ago the 4.11 are stronger becuase of less teath but who no's
Old May 20, 2004 | 02:29 PM
Capn Pete's Avatar
"importeater" helped answer that. It has to do with the number of teeth on the gears.
4.10's are very typical GM gears, using 41 teeth on the ring gear, and 10 on the pinion gear (hence 41 / 10 = 4.10 ). Other common ratios such as 2.73, 3.42, and 3.73 also use 41 teeth on the ring, with varying # of teeth on the pinion.
4.11's have 37 teeth on the ring gear, and 9 on the pinion (37 / 9 = 4.11) but having less teeth on the same "size" of a gear, makes the teeth thicker and therefore stronger.
Old May 20, 2004 | 02:30 PM
Look here, http://www.geocities.com/greasemunkeey/411vs4101.jpg, you tell me There is a big difference believe it or not 4.10's = 41 ring teeth 10 pinion 4.11's = 37 teeth 9 pinion.. less teeth in the same amount of area = bigger teeth = stronger teeth.
Craig
EDIT: Click and drag the link to the address bar.. Capn Pete, you read my mind, just about word for word
Old May 20, 2004 | 08:27 PM
Somnambulist's Avatar
4.11 gears are also supposed to have less "whine" than a higher ratio gear...
Old May 23, 2004 | 04:55 PM
kgkern01's Avatar
I have heard from a guy who installs a lot of F-body gears that the 4.11's whine more than 4.10's do, and he doesnt recommend them due to this fact. Is this true?
Old May 23, 2004 | 04:58 PM
no
Old May 23, 2004 | 05:31 PM
Pony Punisher II's Avatar
GM 4.10's are the best to go with. 41:10 teeth, and they NEVER whine. I've installed 100's of these with no problems.
whiteslpz: sent you a PM
-Jason
Old May 24, 2004 | 05:45 PM
thanks guys for answering my question
i guess i'll go with 4:11's if i decide to on my z (getting it this week )
o, and i would've posted earlier but my comp has been f***ed up this week
ddr698
Jan 9, 2015 10:05 AM
Nostang 96z
Sep 10, 2002 08:54 PM
Nostang 96z
Aug 31, 2002 12:01 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
