3:73 or no gear at all
Old Feb 27, 2010 | 11:55 PM
cutlassryder's Avatar
I have a 3:73 gear in a positive limited slip rear end. at 3000 rpm's im getting about 60 mph. I want to at least be able to reach 100 mph with my gear installed. what do i do. try a 700 r4 trans and take out my 350 turbo, or take out the gear and put in a smaller one. Dont get me wrong its great from red light to red light but the freeway sucks. I have 22inch wheels with a 265 35 22 inch tire. Diameter is 29 inches. What do I do folks
Old Feb 28, 2010 | 10:05 AM
rskrause's Avatar
Moderator
What is the make/model/year of your car? More info would be helpful.
Rich
Old Feb 28, 2010 | 04:01 PM
1988 olds cutlass supreme. chevy engine and trans. 350 block .60 over. Dome trough pistons. 11:1 compression. Eagle steel crank, with roller rockers. 501 lift comp magnum cam. 2800-3000 stall. stock vortec heads
Old Feb 28, 2010 | 05:08 PM
thebufenator's Avatar
try a 4 speed
Old Feb 28, 2010 | 07:24 PM
rskrause's Avatar
Moderator
An overdrive trans if you can swing it.
Rich
Old Feb 28, 2010 | 09:05 PM
will i lose my bottom end power that i have now? and when you say a 4 speed do you mean the 700 r?
Old Mar 1, 2010 | 04:49 AM
rskrause's Avatar
Moderator
TH350 = 2.52/1.52/1.0:1
700R4 = 3.06/1.63/1.0/0.70:1
So, first gear is lower in the 700 = harder launch.
Rich
Old Mar 1, 2010 | 05:16 AM
Or:
http://www.gearvendors.com/hotrods.html
Works great with my 3-speed TH400, 4.11 gears, 25.7" street tires.
blkWidow
Apr 21, 2015 01:56 PM
REDNECKISBOSS
Apr 17, 2015 07:14 AM
CARiD
Apr 8, 2015 08:08 AM
Dr. Weir
Aug 2, 2002 02:36 AM
