Tire pressure for et streets
Old Sep 8, 2002 | 03:43 PM
Frank95z's Avatar
Post Tire pressure for et streets
What tire pressure and size tires are you running. Also what 60fts. Any info appreciated. Frank95z
1995 Z28,Mystic teal metallic,A4,52TB,pulley,as&m headers,Crane 210/224,Strange 12bolt,Et streets Best 11.66 114.62 1.51 NA
Old Sep 9, 2002 | 09:10 AM
TedH's Avatar
Post
Depends on the power and suspension. My 60's are from 1.58-1.63 depending on weather. I run 15.5 pounds of air. I use 28" x 12.5 x 15" ET Streets. Unless something is severely wrong I always hook.
I know a lot of guys running less air than myself. I try and have as much air in the tire that will hook to reduce rolling resistance at the top end and to help keep my reaction time consistent.
'94 Black Z28, 383, 700R4
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Sep 9, 2002 | 09:35 AM
blkchevyz's Avatar
Post
i run mine around 12 psi... im running the 26 x10.5 15s and they dont really hook too well with more air pressure. but be careful if you run them that low, i already spun mine on the rim.
Old Sep 10, 2002 | 05:48 PM
twistedwedge's Avatar
Post
Quoted directly from mickey thompson website (http://www.mickeythompsontires.com)
under tech bulletins
VEHICLE WEIGHT TIRE SIZE AIR PRESSURE
2,500 TO 3,000 UNDER 30" 8 P.S.I. AND UP
2500 to 3000 over 30" 6 psi and up
OVER 3,000 UNDER 30" 16 P.S.I. AND UP
OVER 3,000 OVER 30" 10 P.S.I. AND UP
That is what M/T recommends. Many people think that very low pressure is the way to go, according to M/T it isnt.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10. Gonna try to fit 29.5X10.5W ET Drags out back, 15X3.5 up front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.44@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Old Sep 10, 2002 | 08:07 PM
Frank95z's Avatar
Post
Thanks for the suggestions I'm trying to make some 26x10.5x15's work on my car. And was wanting some starting points thanks again. Frank95z
Old Sep 10, 2002 | 08:30 PM
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by twistedwedge:
</font>
I don't know where MT is coming from. On my 4,100lb race weight car best results are 12-13psi. Could be that isn't safe, but it's what I have been running. That's one reason for the tubes and rim screws . Best 60' to date is 1.54sec. MT also says a "light haze" instead of a smokey burnout, and that's also wrong, IMHO.
Rich Krause
'95 Z-28 383: Vortech, nitrous, etc.
AIM: rstevenkrause
Moshbmx1
Jan 20, 2015 03:27 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
Brady
Jul 29, 2002 10:30 PM
Azimiut
Jul 22, 2002 05:47 PM
