TA questions
Old Aug 29, 2007 | 06:56 AM
  #16
madman69's Avatar
Originally Posted by Z-RATED94
Iv'e checked out the picture on Thunders web site, and that is why I was wondering about making a few plates to adjust the front of the TA if needed. But when looking at the Madmad TA I just don't see anything that looks like a slider, even though the discription says it has one.
The slider is the front mount. The front rodend slides into the bottom bar its is the same principle as the pivot except you can lower or raise the front of the arm to change instant center.
Case in point. This weekend we took Bradys BBC with a procharger out and we moved the front of the t/a up to make it level with the ground. At the hit the car would pick up the front end about 8" and roll out. By the 60ft the car started spinning the tires. We moved the arm back downhill in the front and the car did the same thing at the launch but kept the nose up after the 60ft cone and stayed hooked up all the way down track.
Old Aug 29, 2007 | 09:27 AM
  #17
Is that a change from the earlier design?
Old Aug 29, 2007 | 09:41 AM
  #18
madman69's Avatar
Yes Fred you convinced me!! Although this design has been out for 5 years.
Old Aug 31, 2007 | 12:51 AM
  #19
OneFlyn95z28's Avatar
And THIS is why I have a Full MADMAN kit sitting here.
Tired of the car hooking then letting go down the track.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
