Scatter shield
Old Jul 22, 2003 | 12:40 AM
97TA-WS6-Con's Avatar
Scatter shield
I believew that manual trannies faster then 11.99 need to get a scatter shield.
What do you guys do? get one fabricated or is there a place tobuy one?
Old Jul 22, 2003 | 12:51 AM
Stephen 87 IROC's Avatar
Try at Mopac
Running 11.99 and quicker you need an SFI flywheel shield. You'll also need an SFI clutch and flywheel.
Old Jul 22, 2003 | 04:09 AM
rskrause's Avatar
Moderator
As far as I could find out, no one makes an SFI rated bellhousing for the T56/LT1 combo. I did ding someone who could make a custom one for ~$1,500 though. And it wouldn't be a "bolt in". Some fabbing would need to be done to get the clutch to work.
Rich Krause
Old Jul 22, 2003 | 09:03 AM
Rich: What are we suppose to use to satisfy the tech guys at the strip?
I know you can buy a blanket for about $180. Will that do?
I have the Mcleod street twin and I assume that is SFI approved.
Old Jul 22, 2003 | 09:08 AM
Isn't the new McLeod "universal" bell housing SFI-rated? But then there is the question of whether it requires the LS1 version of the concentric slave cylinder?????
Old Jul 22, 2003 | 02:21 PM
rskrause's Avatar
Moderator
I think it's "yes" and "yes". This was not available when I looked into it, so it slipped my mind. But it is not a bolt-in for an LT1. As far as the clutch/flywheel assembly, I never saw an SFI sticker on one, so I assume it is not certified. However, at the level most of us are running I don't think they are going to tear it down to check.
A blanket is probably the only thing to do to come close to being compliant. Problem is they get grungy very quickly and retain a lot of heat, making them problematic on the street. This whole issue is one reason I went to a TH400, though so far that hasn't been a trouble free conversion either.
Rich Krause
Old Jul 22, 2003 | 03:34 PM
thechef's Avatar
there is NOT a scattershield for the ls1/lt1 cars right now hopefully soon cus i want one and i know several that do also
Old Jul 23, 2003 | 09:21 AM
sideways_Into_3rd's Avatar
i hear 1/4" thick sheet metal welded together to cover up the tunnel makes the techies happy .. thats what i'll end up doing
Old Jul 23, 2003 | 09:32 AM
The new McLeod bellhousing is SFI-rated, according to the McLeod website. . It comes in a universal model, that will bolt most popular manual trannies to an SBC, LT1 or LS1. It allows Viper, LS1, and LT1 T56's to be interchanged on different cars. I've seen an install in one of the magazines, so they appear to exist. The only question that I seem to recall is whether the LS1 slave cylinder is mandatory, requiring you to start with the LS1 T56.
When I was running the T56 and Street Twin, I used a bellhousing blanket from an automatic. Tech never asked if I had it, or looked under the car.
Quickss96
Jan 29, 2016 05:56 PM
Rich_z28
Aug 3, 2003 03:03 PM
Rich_z28
Classic Engine Tech
Aug 1, 2003 08:12 PM
instigator74
Jun 20, 2003 05:01 PM
gtaguy
Jul 9, 2002 08:43 PM
