H&C LT1= 10.8 on DRs
Old Oct 3, 2005 | 07:14 PM
  #16
Silvershark's Avatar
Re: H&C LT1= 10.8 on DRs
It doesnt even look like you did any weight savings mods... Totally unbelievable.
Old Oct 3, 2005 | 08:07 PM
  #17
GMRULZ's Avatar
There are some weight savings mods and he has 3:73`s I beleive.
Old Oct 3, 2005 | 09:07 PM
  #18
Quickshotkimber's Avatar
I have done a bunch of weight saving mods. Just not the one that involves me and a diet It still has the stock leather seat and stock brakes along with a new 5 point rollbar.
Old Oct 6, 2005 | 02:47 PM
  #19
rje's Avatar
rje
Quickshotkimber, you should look into a pair of the Hoosier radial slicks in a 30x9x15 like I have. They work great, I had a 1.50 60ft this past weekend and they should help your combo as well.
Randy
Old Oct 8, 2005 | 12:41 PM
  #20
Randy
Thanks Randy, I just think they may be overkill with only a 4.10 gear. I want something that will let me use the gear at the line and still make it through the traps. I'm gonna try a 28" QTP in the hopes that it will grow enough on the big end.
Old Oct 8, 2005 | 01:48 PM
  #21
T/A lt1's Avatar
Quickshot, the QTP's will help b/c they will grow unlike the Drag radials. I think your converter maybe slipping a little more than you need to. It would be fine if you could turn your stock bottom 7500-8000rpms but that would be dangerous.You should be able to run over 122mph with 4.10's, 28inch tires and a 7000rpm limit. Check it out online and find out how much slippage you are getting. What size radial are you running and what torque arm setup are you using? I am running those big 325/50/15's and a stock torque arm but I am looking at going with a Spohn setup but don't know if I should go with a trans mounted or a subframe setup shorter arm setup. With the stock torque arm and some 26x10" ET drags the best I have done is a 1.49 60' but only once and a few 1.50's on the radials with the 150jets and 3.42 gears. LMK Later Clint
Old Oct 8, 2005 | 04:21 PM
  #22
It is actually running just under 123 with a 275/60/15. I was 60fting between 1.48 and 1.51 each pass. The new cam wants to shift around 6400, perfect for my bottom end. The tranny feels fine, I would just like to bring my trap rpms down a bit. I can feel the car slowing down after 6700.
I run the spohn adj TQ arm that bolts to the subframe.
Old Oct 10, 2005 | 09:51 AM
  #23
T/A lt1's Avatar
Cool, I am about to invest in a Sohn or BMR Torquearm and adjustable Panhard rod in search for low 1.5's N/A and low 1.4's on the bottle. I think you have a little more converter slippage then you may want but it's hard to find a converter that leaves awesome and doesn't slip much. Later and goodluck. Clint
Old Oct 10, 2005 | 07:18 PM
  #24
what kinda hp you putting down btw?
Old Oct 10, 2005 | 07:23 PM
  #25
It made 428 with the old cam. Havn't put this one on the rollers yet. The TQ is out of this world
Old Oct 10, 2005 | 07:27 PM
  #26
It may be slipping a little up top. Might have been a little low on tranny fluid too. The funny thing is that the stall felt a little too tight out of the hole. It seemed to only be hitting around 3600. It works well for the street but leaves a little on the table at the track. BTW, you will love the TQ arm. I cracked the hell out of my tailshaft cutting 1.51 with the stocker and 10 bolt
Old Oct 11, 2005 | 10:31 AM
  #27
Joes94TA's Avatar
James get the slicks and lets stop guessing... by the way Jesus loves you...lol
Old Oct 11, 2005 | 06:16 PM
  #28
Jesus just wishes that I loved him
RichJ
Sep 26, 2002 09:43 AM
donot_4get
Sep 14, 2002 08:03 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
RichJ
Aug 11, 2002 10:14 PM
VeryCrazyBosnian
Aug 3, 2002 10:07 PM
