Elevation Questions
Elevation Questions
Hey guys, I have been looking around alot at peoples ET's.. I have noticed that elevation plays a pretty substantial role in you ET.. My local track is in Hurricane WV .. I was just wondering how I could go about finding out what the elevation is there, and after I find out, how do I get my "real" ET.. is there some kind of mathmatical equation for this?? I have seen alot of people put there time and also say its been "corrected".. Just trying to understand all this stuff..
Thanks in advance
Thanks in advance
Re: Elevation Questions
Elevation plays a part as well as weather. What track do you race at? Sometimes you can google the track and the word elevation and get some hits that will show the elevation of the track. Then use a website that archives their weather days so that you can correct your times. Times are corrected to sea level.
For instance - my best ever time of 12.360@110.82 would correct to:
Based on:
Temp: 64°
Humidity: 21%
Track Altitude: 700 feet
Pressure: 30.48 in.
Density Altitude = 613 feet ET MPH
Uncorrected 12.360 @ 110.82
Corrected 12.28 @ 111.52
Based on:
Temp: 64°
Humidity: 21%
Pressure: 30.48 in.
It took a bit to figure out what track you're talking about.
Kanawha Valley Dragway Park offical altitude is 560 feet. Not a lot compared to higher altitude tracks but with poor weather conditions, you could easily be 2000 - 3000 feet density altitude.
http://www.kanrace.com/
The NHRA altitude correction charts don't even go down below 1,600-ft.
http://www.nhra.com/tech_specs/altitude.html
Using the formulas they use for "stock" class vehicles, for a 560-ft elevation, the correction factors would be:
ET X 0.9957
MPH X 1.039
In other words, a 13.50@105 mph at 560-ft would convert to 13.44@105.4
Interestingly, the NHRA formulas are based on 230.77-ft for ET, and 278.57-ft for MPH, at least that's what you get if you back calculate the numbers they show in the chart.
ET X 0.9957
MPH X 1.039
mark0006
Dec 25, 2014 09:50 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Aneurysm
Sep 14, 2002 03:12 AM
