13.20@109.7 5100da... 2.2 60'
Old Nov 13, 2006 | 12:47 PM
96LT1TX's Avatar
Ok, I got the new motor running ok, and it goes down the track... I just need to learn to 60' all over again. First of all my brakes are so shot that I cant do a real burnout. I just do a rolling burnout to get the stuff off the tires. I then stage, and I was idling out basically because there is no stick to my nittos right now. I have the 555r nitto DRs, and I am thinking that now I need slicks, but what is the best way to get the tires sticky enough to launch at a higher rpm than idle? The new tq is just unreal, I would idle out and then slow into the gas and lose the tires every time.
any advice appreciated
Old Nov 13, 2006 | 01:39 PM
CamaroRacing12's Avatar
fix those brakes or get a line lock....u need to do a burn out and warm those tires up
Old Nov 13, 2006 | 02:39 PM
buzz12586's Avatar
Yea you really need a burnout with the nittos.
Old Nov 13, 2006 | 02:50 PM
MEAN LT1's Avatar
Get some MT drag radials.
Old Nov 13, 2006 | 04:02 PM
Ultra_Dog's Avatar
You suffer from the same failing I have, lousy 60'.
Old Nov 13, 2006 | 09:28 PM
96LT1TX's Avatar
how much you guys think I can gain from getting it into the 1.8 range of a 60' with slicks and skinnies? I really want to beat my friend who has an ls1 w/ a cam and slicks and skinnies, he ran 12.7@112 w/ a 1.9 60'... line lock and slicks/skinnies enough?
Old Nov 13, 2006 | 09:33 PM
MeanGreen97Z's Avatar
Ya with a good 60 foot and a good tune I can see that. You might have a bit left on the table with a mail order tune. Your best off doing a few dyno runs with A/F ratio print out. This will tell you if you have more hp out there.
Old Nov 13, 2006 | 10:10 PM
buzz12586's Avatar
I ran 13.48 @ 103 with a 2.03 60ft. I ran 13.07 @ 108 on a 1.89 60ft. Same mods, close to the same weather. Its amazing what a good 60ft will do.
Old Nov 14, 2006 | 01:37 AM
j0n's Avatar
j0n
oh yes with that mph you can go 12.7 or better. for comparison i trap just under 107mph and go 12.85 on a 1.8 sixty...if you can launch at a real rpm somewhere near your powerband your trap speed should jump up beyond 110mph and a decent 1.8 short time'll get you in the 12.6x range
Old Nov 14, 2006 | 01:04 PM
Ultra_Dog's Avatar
My old best was 13.10 @ 110.65 w' a 2.12 60'. I figure I could get into the 12s with a decent launch.
Boss002
Jul 24, 2015 10:47 AM
GreenbeanZ28
Advanced Tech
10
Nov 1, 2002 01:26 PM
Perry93TransAm
Oct 7, 2002 01:43 PM
DETROIT_AREA_00_SS
Sep 18, 2002 07:33 AM
DETROIT_AREA_00_SS
Sep 13, 2002 07:18 AM
