13.20@109.7 5100da... 2.2 60'
Ok, I got the new motor running ok, and it goes down the track... I just need to learn to 60' all over again. First of all my brakes are so shot that I cant do a real burnout. I just do a rolling burnout to get the stuff off the tires. I then stage, and I was idling out basically because there is no stick to my nittos right now. I have the 555r nitto DRs, and I am thinking that now I need slicks, but what is the best way to get the tires sticky enough to launch at a higher rpm than idle? The new tq is just unreal, I would idle out and then slow into the gas and lose the tires every time.
any advice appreciated
how much you guys think I can gain from getting it into the 1.8 range of a 60' with slicks and skinnies? I really want to beat my friend who has an ls1 w/ a cam and slicks and skinnies, he ran 12.7@112 w/ a 1.9 60'... line lock and slicks/skinnies enough?
Ya with a good 60 foot and a good tune I can see that. You might have a bit left on the table with a mail order tune. Your best off doing a few dyno runs with A/F ratio print out. This will tell you if you have more hp out there.
oh yes with that mph you can go 12.7 or better. for comparison i trap just under 107mph and go 12.85 on a 1.8 sixty...if you can launch at a real rpm somewhere near your powerband your trap speed should jump up beyond 110mph and a decent 1.8 short time'll get you in the 12.6x range
GreenbeanZ28
Advanced Tech
10
Nov 1, 2002 01:26 PM
