Speed density to Maf
Old Jul 31, 2008 | 02:53 PM
Reed44's Avatar
Where can i find a conversion to do this? If I were to go to a junk yard and get the items, what all would I need? How would I do it? Thanks
Old Jul 31, 2008 | 05:34 PM
You need a 94 or newer PCM, with wiring harness and an MAF sensor. The interface to your IAC motor will be a problem.
Old Jul 31, 2008 | 05:48 PM
Reed44's Avatar
So do I have to swap the entire harness? Or can I wire it in?
Old Aug 2, 2008 | 12:29 PM
You can always cobble up your 93 harness, but as a minimum, you would have to modify the injector wiring to handle the full sequential 94+ setup (8 individual injecotr wires, instead of 2 banks of 4 wires). Then you would have to add the MAF wiring, and the extra wires for the 4-wire O2 sensors (your 93 has 1-wire).
Old Aug 24, 2008 | 07:37 PM
Reed44's Avatar
I am going to keep it how it is and tune myself. I am trying to find info on getting this set-up but there isnt alot of info out there.
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pete53
Dec 9, 2014 07:31 AM
Jul 4, 2005 05:00 PM
