Software to delete SES codes?
Old Mar 22, 2007 | 10:15 AM
CrippleFightin's Avatar
Question Software to delete SES codes?
I was doing some reading and I am asking this just to confirm what I am thinking is true.
Can you get freeware software that allows to read and delete SES codes on your car's PCM? If so, when I go to get an emissions test, these codes will not show up when they scan my PCM?
If anyone could answer me these questions and suggest a place to get the software (if it exists), I may be the happiest person on the planet!
Old Mar 22, 2007 | 12:08 PM
VinceTrifecta's Avatar
It's important to make a distinction here. When an SES code pops up, it means the PCM's diagnostic for that SES code failed. You can "delete" SES codes by using an OBD2 scan tool, or disconnecting/reconnecting the battery, but if the root cause of that SES code still exists, the SES code will come back.
Now, you can disable the PCM diagnostics for any of the SES codes using most PCM tuning software. This will prevent the SES code from popping up. However, this won't necessarily guarantee you will pass smog inspection. When the inspection station plugs into your car, they can detect whether certain diagnostics have been disabled, and will automatically trigger a test failure if they do.
Old Mar 22, 2007 | 02:45 PM
I know what the codes are and why they are being thrown. Illinois emissions (if they hook you up to the machine or not) are based on whether or not you are throwing codes. My thing is that I need to pass the the initial test so I am not given the sniff test. I have a cam and deleted the AIR and EGR so without the codes being disabled I cannot pass. I know cammed cars pass all the time in Illinois, I guess I just need to figure out how then.
Old Mar 22, 2007 | 03:09 PM
If AIR and EGR function isn't something the illinois inspection tools look for, you could disable them and pass the no-SES light test if you disable the AIR and EGR diagnostics in your programming.
Old Mar 22, 2007 | 08:29 PM
Mike96z's Avatar
I have EGR/CATS/AIR disabled etc. rear o2s and never gotten failed by the Emissions.
Old Mar 23, 2007 | 06:39 PM
What are some of the free programs used to turn the codes off?
Old Mar 23, 2007 | 06:54 PM
2001NBMZ28's Avatar
No free programs to turn off codes permanently for LS1s, that I'm aware of.
Old Mar 23, 2007 | 06:59 PM
2xLS1's Avatar
There are no free programs that will do thatfor a 99 model. HP Tuners, EFI Live/Flashscan, Jet are tuning packages that you can buy that will, or go to a shop that uses them and pay them to disable the codes.
DirtyDaveW
Dec 1, 2016 05:37 PM
lax037
Aug 18, 2002 02:07 PM
ssfirefighter
Aug 17, 2002 03:19 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
