a scanner question
Old Apr 19, 2007 | 05:12 PM
football4life's Avatar
a scanner question
i got an obd2 scanner and a 95'z with the 16 bit connector but it needs the obd1 is there neway i can use the obd2
Old Apr 19, 2007 | 05:26 PM
2001NBMZ28's Avatar
If I'm not mistaken the '95 is OBDI with the OBDII port - so you need an OBDI scanner with a cable that'll connect to your 16 pin (OBDII) port. If you have an OBDI scanner you can jumper the pins to make it work on the OBDII port, but not vice versa. Am I making sense?
Old Apr 19, 2007 | 05:57 PM
ok i got u if i want to connect to a obd1 which pins do i use
Old Apr 19, 2007 | 06:02 PM
Some OBD-I scanners will come with an adapter to connect the 12-pin scanner connector to the 1995 16-pin connector. If you don't have an adapter, use jumpers as shown in Shoebox's link:
Old Apr 23, 2007 | 03:15 PM
seawolf06's Avatar
Once again Shoebox saves the day via Injuneer! (or is it vice versa???)
Old Apr 23, 2007 | 06:01 PM
Shoebox has the brains... I just point people in the right direction
DirtyDaveW
Dec 1, 2016 05:37 PM
lt1matt
Mar 21, 2015 07:35 PM
aj2494
Mar 12, 2015 10:17 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
