PCM not communicating with OBDII 1995 LT1
Old May 3, 2015 | 08:31 PM
MrHyde's Avatar
Back once again to pick your brains, been having a problem with the car running correctly, so I put the scanner on it worked at first but then lost communication and thats where it stands any information would be appreciated.
Old May 3, 2015 | 09:32 PM
GaryDoug's Avatar
Prominent Member
Re: PCM not communicating with OBDII 1995 LT1
95 isn't OBD2, its OBD1 with a 16-pin connector just to fool you;-) Was that a typo or did you actually use an OBD2 tool? Very few scanners can do those 94/95 cars. See the stickies here for one I wrote for pc. The only handheld that works as far as I know is the Actron CP9185.
Old May 10, 2015 | 10:41 AM
Hasn't been back in a week to check for a response.
Old May 10, 2015 | 04:05 PM
GaryDoug's Avatar
Prominent Member
Probably changed back to his alter ego, Jekyll ;-)
Old May 11, 2015 | 09:56 PM
An Actron CP9145 also works. Probably the 9185's older brother.
Old May 11, 2015 | 10:26 PM
GaryDoug's Avatar
Prominent Member
Yes, his dead older brother ;-) There are some older Autoxray scanners that work also, but I was referring to ones currently available. The older ones that appear on ebay are overpriced and not available for long.
calaban
May 18, 2020 06:43 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
4586
Jan 3, 2015 07:22 PM
joe777107
Dec 1, 2014 09:32 AM
