P1441?
Old Aug 5, 2008 | 12:53 PM
silver97Z's Avatar
Question P1441?
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge -Chevrolet Only
Anyone know what the cause of this code is?
TIA
Old Aug 5, 2008 | 06:28 PM
bobdec's Avatar
Silver, I don't have first hand knowledge on this. but from what I have read there is a vac sensor on the CCP (Charcoal Canister Purge) system. If it detects vacuum when the CCP solenoid is not activated this code is forced. On my '95 the CCP solenoid and vacuum lines setup is on the pass (left) side of the intake manifold. However I can not vouch for the '96 setup. Maybe someone else can chime in and assist. ref shoebox " http://shbox.com/1/1996_evap.jpg "
Old Aug 5, 2008 | 07:01 PM
The vacuum switch (#11 in the diagram referenced above) is correctly or erroneously reporting vacuum in the line when there is no PCM call for it.
If it is correctly reporting vacuum, the EVAP solenoid is probably stuck open (easily checked with a vacuum gauge).
If it is erroneously reporting vacuum, the switch might be bad.
Old Aug 5, 2008 | 08:27 PM
silver97Z's Avatar
Thanks, I'll check it out!
Old Jan 3, 2009 | 03:48 PM
djskiggz's Avatar
Whats the EVAP solonoid?
Old Jan 3, 2009 | 09:23 PM
Part #7 in the evap component diagram linked in the second post in this thread.
Clean97Z
Aug 27, 2009 09:40 PM
djskiggz
Jan 3, 2009 08:36 PM
apyah
Feb 29, 2008 10:19 PM
SS1304
May 19, 2004 07:00 PM
